2001 Pontiac Bonneville Smell *Flood* please Help
2001 PONTIAC BONNEVILLE
JOKERSLYE
I just bought a 2001 Ponntiac SLE Bonneville 71,000 miles. The thing is when i bought the car the Sun roof looked like it was kind of half in but it didnt seem to leak so i said alright its fine. Later on it began to rain and when i woke up the next morning the driver side and passanger side and the back seat floor and my trunk was soaked with water and it stunk bad.. I then found out the sunroof tubes were not hooked up to each other so i got that fixed and then it all stopped but the Trunk and the drivers side floor is still wet .. I cant figure out what it is and the smell has gone away in the front but the Trunk stinks no matter what I throw in there to keep the stink from going away.. SO i was wondering if there is anything I can do to make the stink go away from the trunk ?
Mar 4, 2006 at 3:21 AM
JOKERSLYE
So can anyone help me out please ? I mean it smells really bad in the trunk
Mar 4, 2006 at 3:35 AM
JPAM
  • 307 POSTS
check seals... door seals and trunk seals they might be ript or not setting right....... and stay out of trunk if it stinks :) ... try some drier sheets in trunk... use good smelling kind and that should freshen her up...
good luck.
Mar 4, 2006 at 5:29 AM
DINGO
or febreeze...
works great for freshening up hockey gear :D
dry the area completely if you can and spray liberally.
Mar 30, 2006 at 9:58 AM
