2001 Pontiac Bonneville slipping
2001 PONTIAC BONNEVILLE
164,002 MILES • 6 CYL • FWD • AUTOMATIC
FLOYDB420
First thing in mornings well car is stil cold my transmission slips I can feel it once its warm its fine and my breaks squeal all the time with new pads all the way around but I went cheap with valucraft what should I do I cant afford a new or rebuilt transmission please get back to me
Nov 1, 2010 at 12:06 AM
WRENCHTECH
  • 20,761 POSTS
You have a problem on both fronts here. If your transmission is slipping, then your likely looking at a rebuild and nothing less. The brake issues your having is exactly what happens when brakes jobs aren't done correctly and use substandard parts. There are a number of steps that should be taken during the brake work to avoid that starting with resurfacing or replacing the rotors.
Nov 1, 2010 at 1:38 AM
