My Bonneville will not start unless I fiddle witht he shift lever. Where is the neutral safety switch located and is it adjustable?
Aug 18, 2009 at 4:24 PM
JMALECKI
✓Experienced Mechanic
Hello
It is located on the shifter where the linkage or cable attaches and yes it is adjustable there are 2 bolts loosen them slightly and move the switch to adjust then re tighten the bolts.
John
Aug 19, 2009 at 12:28 PM
THOMAS FREESE
MEMBER
At times getting trouble code.
Aug 18, 2019 at 2:59 AM
(Merged)
SATURNTECH9
What is the exact code number you are getting?
(Merged)
THOMAS FREESE
MEMBER
I don't have the code number available but on my scan tool it
said the PRND switch. Do I just remove the two connectors the two bolts and switch will pull off?
(Merged)
SATURNTECH9
Pretty much dont forget to remove the shifter cable and the arm that it hooks too.Also you will have to adjust the new switch.I posted how to adjust it let me know how it comes out.
Images (Click to enlarge)
(Merged)
THOMAS FREESE
MEMBER
Thank you for the tips and diagrams. I will let you know how things go when I get off the ship I am on at this time (on Dec. 28th). Happy Holidays to you and your family!!
Thanks again, Capt. Tom Freese.
(Merged)
SATURNTECH9
Your welcome thats what were here for hope you have a great christmas as well even though your stuck on ship away from your family.Also thank you so much for keeping our country safe.Please let me know how replacing it comes out and if you have anymore questions please feel free to ask.
(Merged)
MCKCUZZI
MEMBER
1 POST
where exactly is my neutral safety switch is. I have a 94 bonneville se
(Merged)
WRENCHTECH
It's called a Park/Neutral position switch and it's located on the top of the transmission at the shift lever.
(Merged)
THOMAS FREESE
MEMBER
I have replaced the Neutral Safety Switch yesterday following the directions you posted and everything went well! This was my first time using this web site. I thank you again and hope your Christmas Holiday was nice. I don't serve on a military ship I work on a supply ship servicing oil rigs in the Gulf of Mexico. Thanks, Tom.
(Merged)
SATURNTECH9
Your welcome thats what were here for helping people fix there cars please tell all your friends about our site.I had a great christmas thank you.I just assumed you were in the millitary since you said you were on a ship.I have helped a lot of millitary guys with there cars so thats why i thought that.Sorry about that if you have anymore questions you know where to find the answers.
Aug 18, 2019 at 3:00 AM
(Merged)
INTUEY
MEMBER
Engine Mechanical problem
1992 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
Where is the neutral safety switch located?
(Merged)
2CARPRO JACK
On top of the transmission, where the cable hooks to the shift arm.Should haev 2, 13 mm bolts holding it on
