2000 Pontiac Bonneville winshield wipers
25,000 MILES • 6 CYL • FWD • AUTOMATIC
FEGANJ
wipers will not shut off.The contol arm has been replaced.No change.All the speeds work correctly. The wiper stays on intermittent.Only way to shut is pull the fuse
Jun 24, 2010 at 6:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty wiper relay. if OK then wiper switch and wiper motor need tested
Jun 24, 2010 at 6:26 AM
