I NEED ADVICE AS TO WHAT TOOLS I WILL NEED TO REMOVE & REPLACE ALL SPARK PLUGS
May 14, 2009 at 5:35 AM
✓Experienced Mechanic
You will need a spark plug socket, extensions, and a ratchet. Also, you will need to gap the plugs properly. Note: the plugs in the rear are difficult to get to. You may have an easier time of it from under the car.
May 29, 2009 at 6:41 AM
