2000 Pontiac Bonneville passenger window doesnt go down
110,000 MILES • 6 CYL • FWD • AUTOMATIC
FONZIRAMOS2007
  • 11 POSTS
the passenger window does not want to go down i have tried it from the master switch and from the passenger switch but doesnt go down could it be the the motor or the regulator
May 17, 2010 at 12:04 PM
SATURNTECH9
  • 30,869 POSTS
[quote:fa0f84b890="fonziramos2007"]Electrical problem
2000 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic 110000 miles
the passenger window does not want to go down i have tried it from the master switch and from the passenger switch but doesnt go down could it be the the motor or the regulator[/quote:fa0f84b890]
Its most likely the motor you would have to get a multimeter to test for power and ground to see if its the motor or something else.do you have a multimeter?
May 17, 2010 at 12:08 PM
SATURNTECH9
  • 30,869 POSTS
you will need a multimeter to test for power and ground to see if its your window motor or something else.autozone rents meters and other tools like that you just leave a deposite for the value of the tool and you get your money back when you return it.If you want to do some testing let me know when you get a multimeter so i can help you out.
May 17, 2010 at 1:17 PM
