2000 Pontiac Bonneville oil pressure
166,000 MILES • 6 CYL • FWD • AUTOMATIC
PVW59544
My oil pressure gauge is showing 120psi. Normal is 40-45psi. It suddenly jumped to the max. there is no other symptons. i recently had the the intake manifold gasket replaced. the engine is 3.8. I checked the oil level and it was normal but a little formy but not discolored. Do I need to replace the oil pump?
Dec 21, 2007 at 2:56 AM
HFX954
I have the same problem. May be send unit. Mine has been this way for about three weeks.
Dec 22, 2007 at 2:01 PM
