2000 Pontiac Bonneville Ignition switch is stuck in the off
2000 PONTIAC BONNEVILLE
169,000 MILES • 6 CYL • FWD • AUTOMATIC
IMANEDC
Unable to turn ignition switch. Car is in park,
I have tried repeatedly to turn wheels enough to free up ignition switch release, to no avail. I was suspect that I may have somehow activated the security system however, when I'm in the drivers seat and insert the key into the ignition switch the blinking "security" light will go off after several flashes and the ignition switch is still stuck in the off position.
Jun 28, 2008 at 5:47 PM
SHRPCAT
Try spraying something like WD-40 in the mechanism. I have had this happen a few times and the spray always cured the problem.
Oct 26, 2008 at 6:17 PM
FFWILLY
try tapping on the "end of the key" a couple times with a hard object, then try it. If this works, you need to lube the lock cylinder(the part the key goes into). I replaced mine with a new one though. Didn't want to tap the key each time to start for the next ?? years. Good luck.
Jan 21, 2009 at 9:08 PM
