2000 Pontiac Bonneville high oil pressure all of a sudden--
2000 PONTIAC BONNEVILLE
115,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMP
our oil pressure all of a sudden went from like 60# to almost 120# do you know what would cause that ?
Question #2----when it gets freezing out, the rear suspension gets still and one side sits and inch higher than the other, and when you hit a bump in the road the car feels like a lumber wagon, and like jolts or dashes or wobbles ?? from like the back right to the front left, like teters, and almost gives you whip lash and and a sore butt....any ideas, or have you ever heard of this before on this model ?
Thanks
Jim Pesch
Dec 20, 2007 at 7:36 AM
Q1- Check the oil pressure with a mechanical gauge if it checks out-replace the oil pressure sending unit-if not normal consider replacing the oil pump.
Q2- Have the rear suspension checked out could be the struts/control arms.
Dec 20, 2007 at 7:45 AM
