2000 Pontiac Bonneville HIGH OIL PRESSURE
2000 PONTIAC BONNEVILLE
87,000 MILES • 6 CYL • FWD • AUTOMATIC
CL74EVANS
MY CAR JUST DEVELOPED THE SAME PROBLEM, EXCEPT MINE IS JUST PEGGED OUT AT 120. I REPLACED PVC AND PROBLEM REMAINS. I NEED TO RESEARCH MORE, BUT JUST HAPPENED TODAY.
Dec 16, 2007 at 3:23 PM
You need to check the oil pressure with a mechanical gauge if it continues to be high -oil pump problem with the pressure relief valve. Could be the sending unit or the gauge itself
Dec 16, 2007 at 4:22 PM
