2000 Pontiac Bonneville hesitation
123,000 MILES • 6 CYL • FWD • AUTOMATIC
JVELLA929
When driving in different weather conditions and speeds, my car hesitates. It almost feels like I'm running out of gas. I've had the fuel injectors professionally cleaned and the fuel filter changed hoping that would solve the problem. I've also had new plugs and wires installed. It doesn't seem to be a shifting issue and when I'm idleing there's no significate sputtering. Someone told me it may be the fuel pump getting ready to go but...
The car drive great except for this one issue. Also I've checked the gas mileage and I'm getting between 21-25 mpg in the city! There's no check engine lights on either. Do you know what could cause this hesitation?
May 15, 2008 at 1:07 AM
DRCHANDLER
[quote:d6141fd922="jvella929"]Engine Performance problem
2000 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic 123000 miles
The car drive great except for this one issue. Also I've checked the gas mileage and I'm getting between 21-25 mpg in the city! There's no check engine lights on either. Do you know what could cause this hesitation?[/quote:d6141fd922]
Did you end up solving this problem? I am currently experiencing the SAME exact thing. Have changed 3 sensors, fuel filter, and plugs. But it still have not solved.
Apr 27, 2009 at 9:05 AM
DAN ASSINK
[quote:80d3ed4fb5="DRchandler"][quote:80d3ed4fb5="jvella929"]Engine Performance problem
The car drive great except for this one issue. Also I've checked the gas mileage and I'm getting between 21-25 mpg in the city! There's no check engine lights on either. Do you know what could cause this hesitation?[/quote:80d3ed4fb5]
Did you end up solving this problem? I am currently experiencing the SAME exact thing. Have changed 3 sensors, fuel filter, and plugs. But it still have not solved.[/quote:80d3ed4fb5]
please post i am also having this problem
Oct 8, 2009 at 1:51 PM
