2000 Pontiac Bonneville grounding issue?
2000 PONTIAC BONNEVILLE
80,000 MILES • 6 CYL • FWD • AUTOMATIC
REDWATTS
When the weather is hot, I loose the instrument gauges, radio and power windows. AC also goes off but the blower stays on. I also lose remote entry. the car will run in this conditon but wont restart. it will all revert to normal operation when it cools down. I have changed battery and cleaned connections. I found the ground iunder the back seat and engine compartment are there others? I would take it in but it wouldn't do it at their shop.
Aug 30, 2010 at 5:28 AM
WRENCHTECH
  • 20,761 POSTS
That sounds more like a problem with the Body Control Module failing from the heat. Obviously that would have to be confirmed by a shop and they will have to be able to duplicate the problem.
Aug 30, 2010 at 5:51 AM
