2000 Pontiac Bonneville Delayed Start
116,000 MILES • V8 • 2WD • AUTOMATIC
MARKY11
When I put the key in the ignition, and turn it nothing happens. . after sitting with the key turned the lights on the dash (guages) come on and i am able to start it just fine. . also sometimes the car turns off while its on, while driving, etc and the problem comes up again with the car starting. . wat is my problem???
Apr 30, 2009 at 1:05 PM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter and fuel pump-if pressure okay test the fuel pump relay
Apr 30, 2009 at 1:21 PM
