the light does not come on and all the gauges hit zero at the same time i will head to autozone and have them give me the codes thanks sandy[quote:6518ecc830="Ernest Clark"]A condition like this should definitely turn on the "Check Engine" light. Even if it isn't on, you should have your computer scanned. AutoZone will do this for free.
Whatever codes are pulled, write back to me and I'll try to help you from there.
It's kind of hard for me to understand what you're saying is happening. Is your oil pressure dropping first, then the engine shuts down? If so, then you have an internal engine issue, probably a worn oil pump or clogged oil pickup/screen.
Whenever you oil pressure drops, it will interrupt the circuit for your fuel pump and the engine will shut down.
If this isn't the case, write back and we'll go from there. But try to explain your problem in a bit more detail.
If I've helped you, please vote for me, as I depend on this to pay my bills. Thanx, Ernest.[/quote:6518ecc830]
Jan 24, 2010 at 11:47 AM
