i had new brake pads put on all around. a moaning sound started. not a squeel; not a grinding. a moan. the sound reminds me of when you fill a glass with water half full, wet your finger, and slowly move your finger around the brim of the glass - that makes a ghostly moan. the sound on my car happens only at the end of a slow stop. i took it back and the guy put on another set of pads - he said it was a different brand but i'm not so sure, now. the sound went away for a while but it's back. my research suggests such a sound may be caused by vibration given the materials in the make up of the pad - ceramics are supposedly the worst for sound, metals second worst, and organic the best at avoiding sound. is this true? if not the pad material, then what else could be the culprit?
Mar 10, 2008 at 1:01 PM
