1995 Pontiac Bonneville Strange popping noise
SAGE MAXWELL
Engine problem
1995 Pontiac Bonneville Engine Size unknown Wheel Drive Type unknown Automatic Unknown miles
I am hoping that someone can help me. I recently noticed that when I accelerate like I have been since I bought the car at least 3 years ago, there is a popping noise that is comming from under the hood of the car. If I push on the gas pedal very slowly it will give slight hesitation but won't give the popping noise that it does if I try accelerating normally. I am on a tight budget so I am hoping that it is nothing major. To get to and from my job I have to travel on a highway, and as you can imagine the extremely slow acceleration is not earning me a lot of friends on the road. I am hoping to get this taken care of on my day off tomorrow when I get my oil changed so the sooner someone can get back to me the better. I will only have access to the internet until 8pm tonight. Thank you in advance.
Daniel
Dec 16, 2007 at 3:34 AM
2CARPRO JACK
  • 11,533 POSTS
Does it make noise on tight turns? might have an axle that needs to be replaced. Sounds like a cv popping under hard load
Dec 17, 2007 at 12:02 AM
SAGE MAXWELL
It usually makes the popping noise when I accelerate. A co-worker thought it was some bad gas and had me put something to help clean the gas up a bit in the tank before I fueled up. It seems to have helped some as I am able to accelerate a bit faster now, but while I was at a final stop on my way home from some christmas shopping, I got out of the car and noticed a slight smell like maybe burning oil. I popped the hood open and there was some very very light smoke coming from the area behind the engine (The area furthest from where I was standing while at the front of the car). It was a very light grey color smoke. I had the guys at wal-mart look at it since I was there. They were running a bit behind with some tire work but took some time out to look at the car for me. The battery cable was very loose. He says that with as much as it was trying to cut out while I had it just sitting there, he imagined that the popping noise I was hearing was some back firing from it cutting in and out. He suggests I have someone take a closer look at it since he couldn't at the time but imagined I either needed a new battery or a new alternator. I had forgot to mention to him and in my original post that the engine had been replaced within 3 years and so was the battery. I also had neglected to mention that my check engine light was on. There is also a squealing kind of sound coming from the engine area as well, but I've heard it well before this year and it's gone away before, not sure if it might have anything to do with the current problem or not but thought I should add the information in.
Dec 17, 2007 at 2:02 PM
2CARPRO JACK
  • 11,533 POSTS
The check engine light helps. Have it scanned for codes and get back to me. Autozone will do it for free
Dec 17, 2007 at 11:37 PM
SAGE MAXWELL
Sadly I won't be able to get it to there. I went to pull out of the drive today and it died on me. My dad, who works for a car company and used to do a lot of car work, has looked it over and says he thinks it's shot. I thank you for your time though.
Dec 18, 2007 at 7:13 AM
