2000 Pontiac Bonneville 2000 Bonneville Vibration at 46-54
2000 PONTIAC BONNEVILLE
JP2000
Drive Train Axles Bearings problem
2000 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
My 2000 Bonneville has a vibration only when accelerating and only between 46 & 54 mph. I have had the tires rotated and balanced 3 times. I have replaced the brakes rotors calipers. I replaced a worn tie rod end. I had a front end inspection done. I replaced both front hub assemblies. Any idea what could cause this. It shakes the whole car when accelerating lightly and if you let off the gas it stops instantly.
Nov 11, 2009 at 12:10 PM
  • 110,244 POSTS
has anyone checked the CV joints?
Dec 16, 2009 at 2:53 AM
JP2000
Yea I ended up replacing drivers side drive shaft.
That was the problem
Dec 16, 2009 at 3:09 AM
