2000 Pontiac Bonneville
2000 PONTIAC BONNEVILLE
82,000 MILES • 6 CYL • FWD • AUTOMATIC
LEEDOGG
i drove car this morning to work it was fine, came right out 5 min later after parking tired to start, got nothing, no crank, no engine noise nothing. u turn the key and its silent it does nothing, car has full power, pressure tested and low fuel pressure, replaced fuel pump, and still nothing, what should I look for next? i also put some intake cleaner in the throttle body and the car started and ran on that for a min or so then died, that was before i replaced the fuel pump, u can hear the fuel pump turn on, then turn off, please help me!
thanks!
Jan 8, 2008 at 4:04 PM
  • 31,937 POSTS
Hi there,
Test for injection pulse, and report back findings.
Mark (mhpautos)
Jan 8, 2008 at 6:05 PM
LEEDOGG
how do u do that
Jan 8, 2008 at 11:55 PM
  • 31,937 POSTS
you will need what is called a noid light or a LED test light, remove injector plug and fit light or test tight in circuit and crank engine light should flash, this is the pulse that opens the fuel injector.
Mark (mhpautos)
Jan 9, 2008 at 12:12 AM
LEEDOGG
i found out it was the starter
Jan 9, 2008 at 4:45 AM
