1999 Pontiac Bonneville Torque Converter
1999 PONTIAC BONNEVILLE
JOE98661
Transmission problem
1999 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic
Trying to change torque converter clutch selenoid and can't find it. I pulled the side plate on transmission and its not on the transaxle. cAN YOU HELP
Oct 4, 2010 at 5:52 PM
DOCFIXIT
  • 18,828 POSTS
Need to remove pan drain fluid remove filter TCC inside. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.trans
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_638.jpg
Oct 5, 2010 at 3:20 AM
