1999 Pontiac Bonneville security light
JOSHUA1414
Computer problem
1999 Pontiac Bonneville 4 cyl Two Wheel Drive Automatic
My car was working fine one day and then i was cleaning it out and then i went to move it again and then the security light came on and now it wont start I dont knoe what to do.
Apr 17, 2010 at 12:22 PM
  • 110,248 POSTS
If the security light is on, then the system has shut down the engine. What you need to do is have it checked by a dealer. THey are the only ones that have the proper equipment to identify where the problem is coming from. THe only thing you can do is try a different key. If that doesn't work, turn the key to the run position for 10+ minutes and the car should start.
Let me know what you find.
Apr 18, 2010 at 8:06 AM
