1999 Pontiac Bonneville puttering lose of performence
199,425 MILES • 6 CYL • 2WD • AUTOMATIC
ROBB_DOG
my 1999 pontiac bonneville check engin light came on it only flashes it putters and shakes when im at an idle and the same when i take off put doesnt seem as bad its done this in the passed and i used fuel injector cleaner and it fixed the problem for awhile i used it again and it has helped alittle could this be something with the fuel filter line or pump in someway
Feb 17, 2010 at 9:44 AM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Feb 17, 2010 at 10:34 AM
