Car surges, sputters, and chugs. Has trouble gaining and maintaining power. It goes, doesn't go, then goes, doesn't go, doesn't go, goes, etc...
Sep 22, 2009 at 8:38 AM
✓ASE Certified Mechanic
Has the check engine light come on? Have you checked the catylatic converter to see if it is plugged?
Sep 23, 2009 at 8:25 AM
CHUGJAM
MEMBER
Check engine light is always on. How do I check the catalytic converter? I did remove the fuel filter and clean the injectors. This helped as the car does not surge any longer. However, it stalls out when making right turns. It has not yet returned to surging as of yet but it feels like it wants to.
Sep 28, 2009 at 10:56 AM
First, if the ehcek engine light is on, have it scanned before doing any more work. Most nationally recognized parts stores will do it for free, and it should point us in the right direction,
Let me know what you find.
Sep 28, 2009 at 11:19 AM
CHUGJAM
MEMBER
I did that, but no one around here seems to have an OBD 1 scanner.
A new development though.
Engine now has a clanking noise on the passenger side. The car sputtered so I pressed accelerator and it slammed into gear, I mean it was a big bang and a jut forward. Since then, this clanking noise has been present.
Sep 29, 2009 at 10:57 AM
