1999 Pontiac Bonneville head gasket
1999 PONTIAC BONNEVILLE
170,000 MILES • 6 CYL • FWD • AUTOMATIC
TAYLORBOOK
will head gasket fix and flushing radiator and getting oil changed fix the problem,
or do i need to replace head gasket
Sep 21, 2010 at 1:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if you mean using the gasket in a tube type stuff to seal a failed head gasket then i never recommend it, in the end they just cause a much bigger mess. best just to remove head and replace gasket correctly.
Sep 21, 2010 at 3:04 PM
