1998 Pontiac Bonneville Engine replacement
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
DMACKENZIE
I'm replacing the engine in this car does it need to come out the top or the bottom?
Nov 29, 2009 at 6:32 AM
CHEVELLE6969
IF YOU HAVE AN ENGINE HOIST THE ENGINE WILL EASILY COME OUT FROM THE TOP,IT IS MY PREFERRED METHOD. BUT A LOT OF PEOPLE REMOVE THE SUBFRAME WHICH UNLESS YOU HAVE A CAR LIFT IS NOT AS PRACTICAL FOR A SIMPLE ENGINE REPLACEMENT.
Nov 29, 2009 at 10:37 AM
