Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Bonneville
Engine
Symptoms
Compression
1998 Pontiac Bonneville Cylinbder compression Spec
1998 PONTIAC BONNEVILLE
90,000 MILES • 6 CYL • FWD • AUTOMATIC
ROMADU
MEMBER
1 POST
What should the psi be for the cylinders?
Mar 15, 2010 at 10:19 AM
BLUELIGHTNIN6
Experienced Mechanic
lowest compression reading should not be less than 70% of highest compression reading. compression should be at least 100 psi or higher.
Mar 15, 2010 at 10:30 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
