1998 Pontiac Bonneville Blower on, engine off
1998 PONTIAC BONNEVILLE
156,000 MILES • 6 CYL • FWD • AUTOMATIC
KAREN PETTIJOHN
  • 5 POSTS
I had a problem with rats in my neighborhood and they decided to take food up into my air conditioner blower housing. I had no idea they could drag chunks of fruit with rinds and cactus flower parts up there. All of a sudden my air conditioner started making a loud crunching rattling sound. I pulled over and turned off the car because I didn't know what had happened. To my surprise this did not stop the noise so I unhooked the neg cable which worked. I called a friend and he said to pull the master relay next to the fire wall. I did and this worked so I could drive it. We took out the blower and cleaned it out but itstill won't shut off with the engine. any suggestions?
Jul 30, 2009 at 11:32 AM
Try removing the blower motor relay and see what happens.
Jul 30, 2009 at 11:47 AM
KAREN PETTIJOHN
  • 5 POSTS
Is this the large fuse next to the firewall? if yes then that's what I did. I would like to know what is causing the problem so I can fix it and have air conditioning in this 100 degree heat. If not then where exactly is this relay?
Jul 30, 2009 at 12:00 PM
