1998 Pontiac Bonneville
2008STEELERS
  • 1998 PONTIAC BONNEVILLE
  • 6 CYL
  • 130,000 MILES
My car will just shut off and not turn back on, ill try to start it and it will spit a spudder but will not run if I wait 3 hours it will run fine it may run fine for a few days then do it agian could it be the computer? There are no codes when the car shuts off the windows and locks will not work
Thursday, October 29th, 2009 AT 10:12 PM
MERLIN2021
  • 17,250 POSTS
Could be an intermittent wiring/connector probem, is you SES light on when it happens? If so get the codes read, Autozone reads em for free, it will point you to the bad area.
Friday, October 30th, 2009 AT 2:49 AM
2008STEELERS
The sse light is not on there are no codes I had the computer checked it is ok, could it be the ignition control mod, the windows stop working to when the car shuts off
Wednesday, November 4th, 2009 AT 12:44 PM
MERLIN2021
  • 17,250 POSTS
It could be the module, or a bad ground wire connection to the block or frame. Could even be the ignition switch. Remove the module, take it to the parts store, they can test it for you before you buy a new one.
Friday, November 6th, 2009 AT 2:19 AM
