1998 Bonneville P0122 error Code
KOZUBH
  • 7 POSTS
I have 1998 Pontiac Bonneville with 141,000 miles. About four years ago, the engine (3.8liter) was replaced at 96,000 miles when coolant got into the cyclinder #2 and destroyed the engine. Two weeks ago, I had a small coolant leak and suspected the intake manifold and had it replaced. The check engine light came on and has been on ever since the intake manifold was replaced. I changed the throttle position sensor this last weekend and reset the error message. Error code P0122 came back on after one day. What else would you recommend I try to remove the check engine light and this error code. Thanks in advance
Mar 6, 2006 at 10:53 AM
KOZUBH
  • 7 POSTS
After replacing the TPS sensor, I wa still recieving an error message. As it turns out, the middle connector pin on the TPS sensor had a loose connection. I was able to go to the GM dealer and just get a female connector pin and insert it into the connector. They had five boxes of miscellaneous connectors and let me have the one I needed for free. By the way, the dealer wanted $25.00 for the connector and it was a special order.That seems to solve the problem.
Mar 8, 2006 at 7:27 AM
