1997 Pontiac Bonneville oil pressure
1997 PONTIAC BONNEVILLE
146,566 MILES • 6 CYL • FWD • AUTOMATIC
CHUCK MERCER
i have good oil pressure at startup but when engine warms up the oil pressure drops almost to the red on the guage and a chatter starts. could this mean the oil pump needs changed or could it be the oil pressure switch. if it is the oil pump, do you recomend a rebuild kit or total pump replacement.thanks for your input, chuck
Mar 18, 2010 at 3:37 AM
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and/or engine bearing.
Mar 18, 2010 at 9:58 AM
