1997 Pontiac Bonneville gas tank leakage
1997 PONTIAC BONNEVILLE
129,000 MILES • 6 CYL • FWD • AUTOMATIC
HEWSON
Only when I put gas in my car does it leak and a puddle appears under the car. Can you only replace the hose leading to the gas tank wihtout replacing the whole gas tank.
Oct 20, 2008 at 2:54 AM
  • 110,244 POSTS
Hi:
Yes the rubber filler tube can be replaced. Make sure where it's leaking from. It could be a rust that caused a hole in a steel component.
Let me know so I can better direct you.
Nov 7, 2008 at 2:25 PM
