how do you change a coolant temp sensor on 1997 pontiac bonniville
Aug 14, 2008 at 5:20 PM
SCO99888
MEMBER
it is a thermostat not a sensor,it is in the main hose running into the engine from the radiator it sits inside the housing take off the 2 bolts pair of thin plyers and pull it out make shure to buy a new gasget also this shouldnt take more then 10 min make shure the car is cold also dont want to burn your self.
