My 1997 Bonneville back in Feb and it was below zero would not shift from od to lower gears like when you would stop at a stop sign and try to get up to speed. Now it is sifting hard and kind of stuttering when going up hills at 55 or so. I had a mechanic friend of mine hook it up to the computer and it is blowing a P1655 code which is evap emission purge sylinoid control circuit which in the book says something about shifting of the trans as well. I checked the fluid in the transmission and it smells like is burnt...but not real bad. I am wondering if it could be the trans sylinoid and also a new trans filter and flushing would fix? Please help! Thanks!
Sep 2, 2009 at 6:54 AM
