1997 Pontiac Bonneville antifreeze
1997 PONTIAC BONNEVILLE
MISSISSIPPI723
Engine Cooling problem
1997 Pontiac Bonneville 6 cyl 243000 miles
I am losing antifreeze after driving a long distance (200 miles)after I stop, looks like it's coming from the back of the motor but I can't tell, It does not look like it is coming from the radiator or hoses,
any idea?
Thanks
Aug 3, 2009 at 5:19 AM
  • 110,244 POSTS
On the passanger side, check to make sure the water pump isn't leaking. If it is coming from the rear of the motor, chances are it is a freeze plug.
Aug 5, 2009 at 12:02 PM
