1997 Bonneville Se Doors Locks Problem !
MOPARFANS
I own a 1997 Pontiac Bonneville SE Full Equip ! My doors locks are not working fully ! I can Lock the Doors with the Switch but I cant unlock them with the Switch ! I think its an electric Problem but I can't find where is it ! If somebody know how to fix my problem it will be very appreciated!
Andrew :roll:
Jan 1, 2006 at 7:24 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the unlock command and circuit checked at both switches and the affected doors using the matching wiring diagram. Include a mechanical linkage inspection.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use matching vehicle specifications.
Read the replies · Discussion summary and reported outcome
PHIL
My guess would still be the switch. They can work one way and be bad going the other way
Jan 1, 2006 at 1:22 PM
MOPARFANS
Maybe but its not working on the both Switches ! Passenger and driver switch doesn't Unlock but Lock..
Jan 1, 2006 at 4:51 PM
LIGHTHOUSES
have you had your doors apart prior to all this. sounds like the lock rods are hung up or they popped out of the guide
Jan 12, 2006 at 12:28 PM
Discussion summary
The owner of a 1997 Bonneville reported that both door switches could lock the doors but neither could unlock them. Replies suggested switches or disconnected or binding lock rods.
Reported outcome: No failed component or repair was confirmed.
The same symptom at both switches does not establish that both switches failed. No circuit measurements were supplied.
Read the original discussion
