I initially asked a question that I fifured out on my own of how to uninstall the alarm, as the ingnition kill switch would not disengage after the car had sat cold in the winter for a few months. I got the alarm out, the car started right up. I closed the door to back it out of the drive, and just as soon as I closed the door, the whole electrical system shut off and the engine died. I unplugged the battery, and let it sit for another week.
Today I pushed it out of my driveway into the street, to give me more room to work on it. I hooked up the battery, and she fired right up. I let it run for several minutes to get the fluids circulating, and tried to roll down the passenger side window with the electrical switch on the drivers side door, and the electrical system again shut down and the engine died.
I pulled to door panel off, to see if there were some loose or damaged wires in the door, and there are none that I can see.
I have unplugged and plugged the battery back in to see if it would reset, however, it still will not start, and the ignition chime is a constant chime, but not full power and faint on the right side of the car. I have checked all fuses in both the left and right side panels, and all visually look to be okay. Not sure how to check the relays. I have access to wiring diagrams through a Mithcell 1 account and cannot seem to track down what I need through them. No wires can be seen to be damaged or not installed.
Jan 30, 2010 at 7:10 AM
