1996 Pontiac Bonneville loss of acceleration
MAMACAT21
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 170,000 MILES
A few days ago my car lost acceleration while in any gear. I've taken it to a repair shop and they can't figure out why. The engine runs and sounds good (but the manifolds are getting red hot), the exhaust system has been checked out( converter was clogged), plugs and wires are good, fuel injectors are fine, no problems show up through a computer scan. The mechanic says that logically the should be a restriction or obstruction causing the problem but can't find any. Any Ideas?
Saturday, July 25th, 2009 AT 2:39 PM
JMALECKI
  • 118 POSTS
Hello
Check fuel pressure the engine is running lean, could be a plugged fuel filter, bad fuel pump or pressure regulator.
John
Sunday, August 16th, 2009 AT 6:01 PM
MAMACAT21
After many weeks of my car being with the dealership mechanics (and a new exhaust system) they have determined the problem with my car is a cracked harmonic balancer. If this doesn't resolve the issue I will repost.
Monday, August 17th, 2009 AT 7:02 AM
