when i start my car in the cold weather the vehicle has a high idle which fluctuates up and down sporadically between 1500 rpm and 3000. i replaced the throttle position sensor i was told if you unplug the sensor and the problem stops then the sensor is bad but i replaced it twice and it did it with both new sensor. Also when i leave my driveway which is at on end of the block and i drive to the stop sigh and come to a complete stop, idle drops to just under 1000 and idles fine after
May 26, 2010 at 9:12 AM
