1996 Pontiac Bonneville Brake Lights
1996 PONTIAC BONNEVILLE
COREYNDR
Electrical problem
1996 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic 101K miles
I have a problem with my brake lights. the two lights on the trunk along with the reverse lights are not working, I have checked the fuse and the connection at the light assembly and everything looks to be ok.
Feb 1, 2008 at 11:40 AM
BMRFIXIT
  • 19,053 POSTS
[quote:efdb6f540d="Coreyndr"]Electrical problem
I have a problem with my brake lights. the two lights on the trunk along with the reverse lights are not working, I have checked the fuse and the connection at the light assembly and everything looks to be ok.[/quote:efdb6f540d]
check if you have signal light
check / replace compo switch
Feb 2, 2008 at 2:24 PM
