1995 Pontiac Bonneville Wiring Problem
1995 PONTIAC BONNEVILLE
200,000 MILES • 6 CYL • FWD • AUTOMATIC
JEROMELEAHY
I am working on 1995 Pontiac Bonneville for a friend. She was on the highway and said the car just died and wont start, so I had her tow it over to my garage. After the truck dropped it, it started right up and died about a minute later. I checked and it was getting spark so I figured fuel pump. After pushing it in my garage I also noticed that the power windows, locks and seat were not working. I called and asked her if they were working prior to the car breaking down and she said yes. So now I am thinking an electrical problem. Battery is brand new by the way the car cranks strong. So I started by checking the basics, fuses are all fine both under the hood and dash. The relays all seem to be fine. I also noticed the the indicator light on the rear defog button is on even with key off and when you press the button with the key on it shuts the dome lights off. All very strange. Now I have all the wiring from under the dash to about the sides of both front seats pulled up and there does not seem to be any obvious frayed wires or cross shorts. I was playing around with the fuse and relay center when suddenly everything started working for a short moment but then stopped. I was hoping I had it traced to that area but have not had anymore success. Is there possibly a computer that controls those things that I don't know about? I'm a pretty experienced mechanic but this problem has me at wits end. I have been working on this car for 2 weeks. Please help and thanks so much!
Jun 29, 2010 at 6:22 AM
INTERNETMECHANIC
  • 700 POSTS
The power window and power seat use circuit breakers. Did you check for voltage at the circuit breakers? The voltage for the ps breaker is hot all the time. Voltage for the pw breaker goes hot with the key on. With multiple issues, I track one circuit, I look for voltage and ground to start. Fixing one circuit may or may not fix everything.
On the other issue, did you use a gage and check fuel pressure? Any applicable trouble codes?
Jun 29, 2010 at 8:22 AM
JEROMELEAHY
Yes I did use a gauge to check for fuel pressure and no trouble codes. The voltage at the breakers is present. I'm almost sure its a cross short. I worked on a geo with an intermittent fuel pump problem that was because of a short with a frayed wire that when you would step on it, it would cause the fuel pump to cut off. It was just way easier to find because the car had no power accessories.
Jun 29, 2010 at 8:27 AM
INTERNETMECHANIC
  • 700 POSTS
With good fuel pressure, good spark, and injector pulse, I can usually get the engine to hit.
Jun 29, 2010 at 9:07 AM
MISFITLADY
  • 6 POSTS
Did you find the problem? I am having the same exact problem with mine. My stepdad has changed coil pack, ignition module, computer, ignition switch, new key switch and key and it is still doing the same thing, it ran for about half a day after he did the coil and ignition module but right back to the same problem
Jul 3, 2010 at 3:37 AM
JEROMELEAHY
Yes I did as a matter of fact. It was the BCM (body control module). Its located under the passenger side dash. It controls all of the interior electrics and the fuel pump. Dealer wants $500 but I got mine from the junk yard for $75. Good luck!
Jul 3, 2010 at 3:45 AM
MISFITLADY
  • 6 POSTS
thank you so very much, my dad and brother were completely stumped and I couldnt afford to keep replacing everything
Jul 3, 2010 at 3:52 AM
INTERNETMECHANIC
  • 700 POSTS
Bonneville SE has no bcm control of windows or seats, according to MOD. There is more than one class of bonneville, though. So you need to know, pontiac bonneville ???.
Jul 3, 2010 at 4:19 AM
MISFITLADY
  • 6 POSTS
yes SE but everything is exactly the same as the original question right down to the rear defog, let me go to the garage and make sure its SE, no its just a bonneville and the book they have they cant find where the BCM is or what it looks like
Jul 3, 2010 at 4:21 AM
JEROMELEAHY
It doesn't matter if its SE or not bud. When you buy the module all they ask you is if you have the anti theft system or not. Supercharged does not matter either. This is an interchangeable part with many GM models so no big deal finding one. Good luck and let me know if that helps you and fixes the problem.
Jul 3, 2010 at 4:33 AM
INTERNETMECHANIC
  • 700 POSTS
Hey, I've been wrong before. Show me the wiring diagram where the bcm controls the windows and seats. I'm just trying to understand. I enjoy talking to you, I'm always willing to learn. thanks
Jul 3, 2010 at 4:55 AM
MISFITLADY
  • 6 POSTS
can you tell me about what the bcm looks like and approximately where on the passenger side its located please?
Jul 3, 2010 at 5:12 AM
INTERNETMECHANIC
  • 700 POSTS
What is the exact year--make--model? There may be more than one class of Bonneville, which bonneville? Need the vin? So far, I am unable to locate a bcm.
Jul 3, 2010 at 5:33 AM
MISFITLADY
  • 6 POSTS
1995 Bonneville vin 1G2HX52K9S4245616
Jul 3, 2010 at 7:26 AM
INTERNETMECHANIC
  • 700 POSTS
According to my info, no bcm in control of seats or windows. Exactly what is your problem? If power windows won't work, there is circuit breaker for voltage, the voltage to the circuit goes hot with the key on, use a voltage tester.
Jul 3, 2010 at 7:57 AM
MISFITLADY
  • 6 POSTS
The problem is exactly the same as the one jerome had along with fuel pump not kicking in, it quit running while I was on the hwy lost everything except the radio, a neighbor brought my stepdad a couple of relays, he changed one out for the fuel pump and its now kicking in everything is working and car is starting like a charm but it done the same thing after he changed coil pack and ignition module, ran like a charm for about 24 hrs and done the same thing over again so Im hoping that this time it is actually fixed
Jul 3, 2010 at 8:38 AM
INTERNETMECHANIC
  • 700 POSTS
There is a rac module under right side of dash? I was pulling my hair out trying to find bcm. I don't have any hair to spare. lol
https://images.2carpros.com/forum/automotive_pictures/512072_rac_module_1.jpg
https://images.2carpros.com/forum/automotive_pictures/512072_rac_module_wiring_1.jpg
Jul 3, 2010 at 9:06 AM
