1995 Pontiac Bonneville want go in all gears
1995 PONTIAC BONNEVILLE
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CHAD JOHNSON
will go in reverse 1st & 2nd but want go in drive if your driving the car you can manually shift the gears and they will go but if the car is sitting then it want shift into gear?
Mar 23, 2010 at 11:18 AM
  • 110,244 POSTS
Is the fluid full and clean? Has the check engine light come on?
Apr 19, 2010 at 12:54 AM
