1995 Pontiac Bonneville keeps shutting off
1995 PONTIAC BONNEVILLE
217,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGJAY70
it will run for a few minutes then the interior lights will shut off then the engine will die. my power windows won't work either. a few minutes later everything will work again. put another computer in but still the same thing also fuel won't get to the injectors then in a few minutes everything is fine. keeps doing it over and over.
Jan 20, 2010 at 3:52 PM
MARK BROOKS
grounding strip under driver and pass floorboard. connection is bad. take strip out and clean connections. Exact same thing happened to my 97.
Mar 17, 2010 at 7:37 AM
