1995 Pontiac Bonneville High beams won't work
1995 PONTIAC BONNEVILLE
245,000 MILES • 6 CYL • FWD • AUTOMATIC
NEEDHIGHBEAMS
I have a 1995 pontiac bonneville SE and the high beams won't engage. I've been able to take a couple things off the steering wheel column and can see a metal rod which I can push to activate the highs. I really need to find out what part connects the end of that rod to the multifunction blinker lever. An image would also be great since I don't know what it is supposed to look like. Thnaks...
Oct 23, 2010 at 6:09 AM
BUDDYCRAIGG
  • 2,262 POSTS
ok, this is just my opinion.
go buy a steering column from a junkyard and swap your ignition lock cylinder in it.
it would be faster than rebuilding your old steering column.
Oct 23, 2010 at 11:15 PM
