1995 Pontiac Bonneville Hesitation.
105,000 MILES • 6 CYL • FWD • AUTOMATIC
VEKTRON1961
I have a 1995 Supercharged bonneville that hesitates on very hard right tuns. It also hesitates when you fully accelerate. I have replaced the EGR valve twice in the past year because the diagnostics at the garage said it was bad but makes no diifference in the way the car runs, of a matter of fact the light came on again saying it is bad but it is not.
If I fully accelerate the car often dies out for a second or two and then takes off although it is not accelarating the whey it should, but if I get on the highway on a hard right turn the car will just die for about 2-seconds and then take off. i believe this problem is a little worse when my fuel tank get down around a quatrer of a tank or so.
Could this be my fuel pump and is there a way I can check it. Thanks Fred
Nov 11, 2009 at 4:26 AM
  • 110,248 POSTS
Are you sure the lines going to the EGR are good? Also, have you checked fuel pump pressure and the regulator?
Dec 16, 2009 at 3:18 AM
