1995 Pontiac Bonneville fuel relay
1995 PONTIAC BONNEVILLE
JESSCJW3
Electrical problem
1995 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
we would like to know if there is a reset button for the fuel relay system, our car runs fine for about 30 minutes or so asnd then starts stalling,dieing, and backfireing, when it dies it wont turn on and if you let it sit for an hour or so it turns back on. what other problems might cause this
Nov 1, 2010 at 10:39 AM
JDL
  • 16,098 POSTS
There is no fuel reset, if you think there is a fuel issue, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. If your fully obd1 compliant, check for mil codes.
When the problem occurs, if it cranks good, have a helper crank it, while you visually check for spark at the plugs.
Nov 1, 2010 at 11:32 AM
