1995 Pontiac Bonneville engine codes and no start
1995 PONTIAC BONNEVILLE
DUNNSAUTOREPAIR
Engine Performance problem
1995 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
The engine codes are p0341 & p0342. The engine turns over but will not start. i know the codes are
related to the cam sensor. i was wondering if a cam
signal problem could cause a no start situation. when turning over it turns freely and every now and then it will hit a lick and then pop back thru the throttle
body. thanks for any info you can give me.
Feb 26, 2009 at 11:23 PM
BILLYMAC
  • 2,204 POSTS
hi yes cam sensor will set a no start situation.
Feb 28, 2009 at 2:00 PM
