1995 Pontiac Bonneville Drivers side wheel gets very hot
1995 PONTIAC BONNEVILLE
177,000 MILES • 6 CYL • FWD • AUTOMATIC
MARK WEINHOLD
New Drive axel, bearing assembly, caliper(re-manufactured), pads, and rotor. The old caliper (original) would not release which caused a cascade involving everything else except the drive axel. worked for a couple weeks. Today a vibration started and the wheel was too hot to touch again (boils water when poured on shaft end. could it be the re-manufactured caliper?
Jun 23, 2010 at 6:36 AM
  • 110,244 POSTS
Have you replaced the rubber brake hose to the caliper?
Jun 25, 2010 at 3:45 PM
