1995 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic
Battery was defective and replaced. Still have absolutely nothing. Not even a click when key is turned. Lights, radio, etc. Do not work either. Acts as if there is no juice anywhere. Jumped across solenoid, with a screwdriver, and the starter will turn over that way. Also seem to have juice to Alernator. But absolutely do not know where else to check. Did check all fuses we could find and they also seem to be OK. What else could I check. Do not have a wiring diagram or could possibly figure it out myself. (Am not a mechanic, anymore, since late 70s, but have extensive background in electronics (TVs and Computers) so could check it out if I knew where to start) Thank You.
SPONSORED LINKS
Monday, September 15th, 2008 AT 2:45 PM
