1995 Pontiac Bonneville coils
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANMESSIN
Would the coils make the car shake when you press the gas pedal at a certain speed or when you set the curse at a certain speed? Also would it mess up your accelertion at a certain speed, when trying to pass a car? It seem to me like it was a fuel injector not getting enough air or gas while running. This problem whatever it is, made my car shut off completely so nothing work with the car, lights went off, power steering didnt work anymore, radio shut off, also the brakes would shut off, it was like the battery was dead and killed my car. I NEED HELP!
Oct 10, 2008 at 8:23 PM
2CARPRO JACK
  • 11,533 POSTS
Coils adn injectors both can cause misfires like you describe. But it sounds like you have bigger problems. Will the car crank at all? Almost sounds like the battery is dead, possibly from a bad alternator
Oct 11, 2008 at 1:29 AM
