1995 Pontiac Bonneville
SEDRICK912
  • 1995 PONTIAC BONNEVILLE
1995 Pontiac Bonneville 6 cyl Automatic
my car acts like its losing power and it sometimes cuts off when I switch it from reverse to drive and it sounds loud
Saturday, May 15th, 2010 AT 6:29 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, May 23rd, 2010 AT 6:09 AM
