1994 Pontiac Bonneville wont crank
DENNY115
  • 1994 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 10,000 MILES
This car was hit in the front end, it was drove too my house, I put anew front end on it, it has dash lights and everything works but when I turn the tumbler I get nothing, ive checked all the fuses and relays, ive replaced the starter, icant here the fuel pump running either, I did remove the battery when I welded the new front end on also, is there a fusable link somewhere that I ive missed? This car has got me dumbfounded!
Sunday, July 26th, 2009 AT 3:49 AM
Try shorting out the starter solenoid if it cranks the engine over-you're not getting power on the purple wire on the starter solenoid-test the neutral safety switch and ignition switch.
Sunday, July 26th, 2009 AT 4:51 AM
